FeatureReader drops a 0 in a 'datetime' in case of reading an OGC Geopackage
  • Feb 22, 2026 12:21 PM UTC
  • 106 views
wilmar
I'm trying to read a OGC geopackage which contains fields of the type 'datetime'.
In FME 2025.1 (which uses version 16 of the FeatureReader) something unexpected happens: in case the number of seconds starts with a 0 (zero), this zero gets dropped after reading the data. See record 21 in the screenshots for an example:
In FME 2025 the field ‘tijdstipRegistratieLV' misses a 0 after the '1009' (10 hour 9 minutes).
In FME 2023 the readout is correct: 20101214100907 (2010 december 14th, 10 hour 09 minutes 07
Is this a known issue/bug?
Best answer by max_h
That error was fixed in 2025.2.1 as it seems:
Geopackage Reader: Cannot parse datetime values in FME 2025.1
Changelog - FME by Safe Software
So I guess try updating and then run the workspace again.
max_h
Forum|alt.badge.img+39
  • Feb 23, 2026 2:45 PM UTC
wilmar
  • Feb 24, 2026 12:27 PM UTC
Thanks, I downloaded FME 2025.2.3 and it is fixed indeed!
