FBX file read with texture mirrored
  • Jul 2, 2019 1:47 PM UTC
  • 191 views
Hi all,
I'm trying to read an .fbx model exported from Infraworks. It appears in the data inspector with textures mirrored and the following warning :
"FBX_1: A texture used by mesh in node 'Mesh N' references a UV set named 'default', which doesn't exist"
I've tried to re-mirror the appearance but nothing seems to work and I don't know how to reference the UV set ... Do you have any idea what am I doing wrong ?
The area in Infraworks :
The area in DataInspector:
the fbx file and others :
Regards,
Louis
sigtill
Forum|alt.badge.img+25
  • Oct 24, 2019 12:15 PM UTC
Hi @louis_c3
Try the FME2020 Beta - there are some changes on the FBX writer. I have also experimented with FME + Navisworks + Infraworks. And it seems that its difficult to get all 3 of them to generate the same FBX file.
Yuo can also use Autodesk FBX Review to look at the FBX file, however it will show differently in Navis/Infra/FBX/FME even though its the same file.
daveatsafe
Forum|alt.badge.img+24
  • Oct 24, 2019 9:32 PM UTC
Hi @louis_c3,
I checked the FBX file you included in Autodesk's FBX Review, and the textures appeared flipped there as well, so it seems to be an Infraworks issue.
I am attaching a workspace that will flip the textures and write to a new FBX file for you.
fliptextures.fmw
roman1
Forum|alt.badge.img+3
  • Apr 24, 2020 5:47 AM UTC
Hello people from the internet who stumble on this thread in hope to fix their Autodesk FBX issues.
If you're going to use @daveatsafe's script below then be advised on following (as of fme version 2020.0 20118):
  • Turn of featurecaching for this script. Script will often not rerun
  • Preview of results from fetature caching will not show you the correct results. You have to write result to a file wuthout featurecaching turned on and view results afterwards. Preferably in another software.
Hopefully it just saved you tons of head scratching.
