Faro Laserscanner Focus 3D - -converter in FME
  • January 20, 2013
  • 29 views
Hello together, I have data of the laser scanner in FME, Faro focus 3D - there a possibility this data in
ArcGIS 3D or ESRI CityEngine 2012
export - converter in FME / or other means of
Thank you to all
Hello,
if you can read the your data with fme, maybe you can translate your data to LAS. I think this is supportet by ArcGis.
Hopefully that works,
best regards,
Stefan
