Fails to convert lines to polygons,
  • Sep 9, 2014 11:30 AM UTC
  • 56 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out why the workbench below fails to convert lines to polygon.
CAD file:
http://www.mediafire.com/download/a3sb8l5cjzcsk5s/Ayman_02.dwg
What might be the issue here?
Thank you
Best
Jamal
Best answer by takashi
Hi Jamal, every day :)
Probably there is a line that doesn't touch with adjoining line at the end point each other.
I would recommend you to always consider "snapping" when the AreaBuilder failed.
Takashi
  • Sep 9, 2014 12:32 PM UTC
Takashi
  • Sep 9, 2014 12:42 PM UTC
I agree completely with Takashi and what's been said before on this subject: Snapping is almost always necessary. Remember that FME works with full precision coordinates, whereas ArcGIS implicitely snaps to resolution grid. This means that FME is much more sensitive to microscopic gaps.
David
jamal
  • Sep 9, 2014 3:44 PM UTC
Many thanks Takashi and David for the help,
With the “snapper” tool, it works fine.
