Facing Read Timed Out issue when writing to ODS connection via JDBC connection
  • Feb 25, 2021 6:06 PM UTC
  • 119 views
I was trying to write data from a JDBC connection to an ODS via a JDBC connection. Some times i am facing the below issue
2021-02-25 20:34:57|1245.3| 0.0|INFORM|MS Azure SQL Database Spatial (JDBC) Writer: Committing feature 197000
com.microsoft.sqlserver.jdbc.SQLServerException: Read timed out
at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:2670)
at com.microsoft.sqlserver.jdbc.TDSChannel.read(IOBuffer.java:1990)
at com.microsoft.sqlserver.jdbc.TDSReader.readPacket(IOBuffer.java:6494)
at com.microsoft.sqlserver.jdbc.TDSCommand.startResponse(IOBuffer.java:7741)
at com.microsoft.sqlserver.jdbc.TDSCommand.startResponse(IOBuffer.java:7700)
at com.microsoft.sqlserver.jdbc.SQLServerBulkCopy.doInsertBulk(SQLServerBulkCopy.java:1615)
at com.microsoft.sqlserver.jdbc.SQLServerBulkCopy.access$200(SQLServerBulkCopy.java:58)
at com.microsoft.sqlserver.jdbc.SQLServerBulkCopy$1InsertBulk.doExecute(SQLServerBulkCopy.java:709)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7344)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:2713)
at com.microsoft.sqlserver.jdbc.SQLServerBulkCopy.sendBulkLoadBCP(SQLServerBulkCopy.java:739)
at com.microsoft.sqlserver.jdbc.SQLServerBulkCopy.writeToServer(SQLServerBulkCopy.java:1688)
at com.microsoft.sqlserver.jdbc.SQLServerBulkCopy.writeToServer(SQLServerBulkCopy.java:669)
at COM.safe.fme.jdbc.mssql.BulkCopierFeatureBundler.sendFeatures(BulkCopierFeatureBundler.java:154)
at COM.safe.fme.jdbc.JdbcWriter.commitTransaction(JdbcWriter.java:674)
at COM.safe.fme.jdbc.JdbcWriter.write(JdbcWriter.java:269)
Caused by: java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116)
at java.net.SocketInputStream.read(SocketInputStream.java:171)
at java.net.SocketInputStream.read(SocketInputStream.java:141)
at com.microsoft.sqlserver.jdbc.TDSChannel$ProxyInputStream.readInternal(IOBuffer.java:1009)
at com.microsoft.sqlserver.jdbc.TDSChannel$ProxyInputStream.read(IOBuffer.java:997)
at sun.security.ssl.InputRecord.readFully(InputRecord.java:465)
at sun.security.ssl.InputRecord.read(InputRecord.java:503)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:975)
at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:933)
at sun.security.ssl.AppInputStream.read(AppInputStream.java:105)
at com.microsoft.sqlserver.jdbc.TDSChannel.read(IOBuffer.java:1983)
... 14 more
2021-02-25 20:35:33|1245.4| 0.1|ERROR |com.microsoft.sqlserver.jdbc.SQLServerException: Read timed out
2021-02-25 20:35:33|1245.4| 0.0|ERROR |com.microsoft.sqlserver.jdbc.SQLServerException: Read timed out
2021-02-25 20:35:33|1245.4| 0.0|ERROR |Azure_ODS_Production_Writer (WriterFactory): com.microsoft.sqlserver.jdbc.SQLServerException: Read timed out
2021-02-25 20:35:37|1249.3| 3.9|INFORM|MS Azure SQL Database Spatial (JDBC) Writer: Committing feature 197000
com.microsoft.sqlserver.jdbc.SQLServerException: The connection is closed.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:233)
at com.microsoft.sqlserver.jdbc.SQLServerBulkCopy.writeToServer(SQLServerBulkCopy.java:1672)
at COM.safe.fme.jdbc.JdbcWriter.close(JdbcWriter.java:183)
2021-02-25 20:35:37|1249.3| 0.0|ERROR |com.microsoft.sqlserver.jdbc.SQLServerException: The connection is closed.
with this log the workbench got stopped and failed.
rahulsharma
Forum|alt.badge.img+12
hi @vioarx​
Can you clarify how are you trying to connect to Azure SQL Server?
Are you using JDBC Reader or Microsoft Azure SQL Database Spatial (JDBC) reader?
Are you able to connect to Azure Server using FME? Please try it using FME Data Inspector.
  • Feb 26, 2021 7:38 AM UTC
hi @vioarx​
I am using JDBC Reader and Microsoft Azure SQL Database Spatial (JDBC) writer.
When using FME Data Inspector I can read all the values.
the error is when I am writing to the Azure SQL Database.
