Facing issue while zipping a text file with master workspace
  • Jul 9, 2019 1:53 PM UTC
  • 28 views
nag
Hello Team,
I could able to zip a text file when i created separate workbench to zip the text file,
But same thing when i did with my master workspace which contains different readers and arcSDE write at that time it is not giving output as .ZIP.
What could be the reason for this unexpected results? and is there any other way around to fix the issue?
I cannot use WorkspaceRunner as my master workspace run through server job.Following are the screenshots of my workspaces,
Below workspace Zipping the downloaded file through HTTPCaller,
Same incorporated with master workspace, Which was not giving expected results,
nag
  • Jul 25, 2019 7:53 AM UTC
Issue has been resolved, Used ZipArchiver to done my job.
