Facebook and Linkedin in FME 2018
  • Apr 16, 2018 2:43 PM UTC
  • 5 replies
  • 86 views
Is there any way to integrate linkedin and facebook with the FME 2018? Make searches for words identical to the tweetSeacher transformer..
Best answer by david_r
If either expose a suitable API, I'm guessing it should be fairly easy to connect to those using the HTTPCaller.
  • Apr 16, 2018 2:46 PM UTC
nathanatsafe
Forum|alt.badge.img+9
Hi @inovacaogis,
Perhaps you've found a solution by now, but we have uploaded a LinkedIn web connection to FME Hub. You'll find instructions on the hub for how to set up the connection and the LinkedIn Developer app for use with FME.
Hope this helps!
Nathan
nic_ran
Forum|alt.badge.img+20
  • Oct 25, 2019 4:59 PM UTC
Hi @inovacaogis,
Hope this helps!
Nathan
Hi @nathanatsafe, I was looking on the Hub for the LinkedIn web connection you mentioned but it doesn't seem to be there.... has it been removed?
jovitaatsafe
Forum|alt.badge.img+11
Hi @nic_ran, thanks for stopping by live chat! @nathanatsafe checked in with the team earlier today and the reply just came in so I'm posting on his behalf. It looks like the LinkedIn Web Connection HUB transformer been removed for now due to changes in the API which means the transformer is not currently working at the moment. Development is in progress for it, although there isn't a timeline set. The issue is tracked as FMEHUB-281.
nic_ran
  • Oct 28, 2019 4:43 PM UTC
Thanks for the update @jovitaatsafe. It would be good to see this connector available again.
