Extraction traits
  • Jun 22, 2022 2:47 PM UTC
  • 9 replies
  • 102 views
fmesafe.podpora
Forum|alt.badge.img+11
Hi. By default we use Property Extractor geometries, but how can this be used if both geometries (part0, part1) have the same name? Thank yougeom
Best answer by fmesafe.podpora
hello, yes, I am sending .The file is large, please download here
https://www.uschovna.cz/zasilka/ZMT9LK2BFW7299FP-W5L/
Thank you
I've already solved it, I probably had a head eclipse. Settings in the attachment. Thank you very much for your interest.
danilo_fme
Forum|alt.badge.img+58
  • Jun 22, 2022 5:32 PM UTC
Hi @fmesafe.podpora​
Please, could you share your data?
Thanks
fmesafe.podpora
Thanks
Thank you
danilo_fme
  • Jun 24, 2022 9:49 AM UTC
Thank you
Thanks.
I maked it. It is correct?
Baseline
fmesafe.podpora
Thank you
Hi. I'm sorry, I was out of work. I can't see anywhere, did you upload somewhere?
danilo_fme
  • Jun 28, 2022 4:15 PM UTC
Thank you
Hi - no problem. Please -how is the format? gml, xml?
fmesafe.podpora
Thank you
xml, AIXM 5.1.
danilo_fme
  • Jun 29, 2022 10:01 AM UTC
Thank you
Please, share your Workspace.
I didn't identify the geometry.
Thanks in Advance - Danilo
fmesafe.podpora
Thank you
I'm sorry, I spoke badly. I need to get these two values between the attributes - extract them. Only traits part0 are extracted via geometrypropertyextractor, but I can't extract part1. WS I'm attaching, this is a branch of DepartureLeg.
Thanks a lot
fmesafe.podpora
  • Jun 29, 2022 1:06 PM UTC
Thank you
