Extracting Min and Max Extents from output of 2DGridAccumulator
  • Mar 5, 2020 12:41 PM UTC
  • 234 views
jugoslaviaa
Hi all,
I am using 2DGridAccumulator, which works perfectly fine. I would like to write also the bbox coordinates of each grid to my final output. I can see those values in the inspector but I don't know how I can extract those attributes so that i can write it.
Any idea how i can do it? thanks in advance.
Best answer by ebygomm
You can use a boundsextractor to get the min and max extents in attributes
Forum|alt.badge.img+54
  • Mar 5, 2020 12:43 PM UTC
