Extract "Version" or "version" from XML.
  • Oct 15, 2018 9:27 AM UTC
  • 69 views
nielsgerrits
Forum|alt.badge.img+67
I would like to extract the value "Version" or "version" (it differs from version to version :x ) from an XML. Usually I do this with a XMLFragmenter but XML is case sensitive so i need to do it twice and aggregate it. I think it can be done easier using XQuery but having a hard time to get it to work. So my questions are:
1. How to extract the value Version or version using XQuery from the next piece:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<Leveringsinformatie xmlns="http://www.kadaster.nl/schemas/klic/leveringsinformatie/v20180418" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:gml="http://www.opengis.net/gml/3.2">
<version>2.1</version>
</Leveringsinformatie>
2. How to learn XQuery?
Best answer by takashi
Hi @nielsgerrits,
1. If one of <version> and <Version> always appears just once,  the XMLXQueryExtractor with this expression is a possible way:
declare default element namespace "http://www.kadaster.nl/schemas/klic/leveringsinformatie/v20180418";
(data(//version), data(//Version))
2. I'm learning XQuery with these resources.
Note: the current XQuery processor 'Zorba' bundled with FME supports XQuery 3.0, so some functionality added in XQuery 3.1 can not be used yet.
Hope this helps.
  • Oct 15, 2018 9:49 AM UTC
Hi @nielsgerrits,
Hope this helps.
nielsgerrits
Hi @nielsgerrits,
Hope this helps.
Thanks for the fast response!
  • Oct 15, 2018 11:25 AM UTC
Hi @nielsgerrits,
Hope this helps.
Variations:
data(//version)||data(//Version)
if (exists(//version)) then data(//version) else data(//Version)
data(if (exists(//version)) then //version else //Version)
data(//*[local-name()=('version', 'Version')])
'Zorba' also supports JSONiq which is an extension to manipulate JSON documents with XQuery expressions. However, there are only few resources to learn that. This is the only comprehensive documentation about JSONiq I found so far. If you found other good resources, please share them with us.
