Extract values from a column
parashari
I know there are already posts about this, but couldn't find much info about it.
I have a column in csv with multiple fields and values in the same column:
col1
{ "21" : 80.0, "81" : null, "21" : 100.0, "21" : 60.0 }
{ "21" : 60.0, "21" : 80.0, "81" : null, "21" : 80.0, "21" : 100.0, "21" : 100.0, "21" : 60.0 }
Representation-
21- max speed
81- max weight
The occurrence of fields:1st time- Car, 2nd time- Bus, 3rd time-Truck
Max Speed (Car)
Max Weight(Car)
Max Speed (Bus)
Max Speed (Truck)
Max Speed(D Truck)
Max Speed (B Truck)
80
null
100
60
null
null
60
null
80
100
100
100
Attaching the csv.
I am able to use AttribuleSplitter, SubstringExtractor and putting them in fields, but the values are not in uniformity. Any suggestions?
Thanks in advance.
Forum|alt.badge.img+39
  • March 24, 2020
If I've understood correctly, i would use a string searcher with some regex to pull into a list all the speed elements and simply rename these, then repeat with the weight elements if required
e.g. regex in stringsearcher
(?<="21" : )[0-9]+\.[0-9]
then rename list elements to attribute
  • March 24, 2020
I read your sample data with CSV reader, this is the result. As you can see there are some unexpected representations such as 82, 105, and 4. How do you translate them?
Could you please explain the rules for mapping all the elements  shown below to desired fields?
col1
"82" : null"21" : 60.0"21" : 100.0"21" : 80.0
"21" : 30.0"21" : 80.0"81" : null"105" : 390.0"21" : 60.0"21" : 100.0
"21" : 30.0
"21" : 80.0"21" : 100.0"21" : 60.0
"4" : null
"21" : 50.0
"21" : 80.0"81" : null"105" : 390.0"21" : 60.0"21" : 60.0"21" : 70.0"21" : 100.0
"4" : null
"4" : null
"21" : 80.0"21" : 100.0"4" : null"21" : 60.0
