extract raster cell size
  • March 18, 2016
  • 9 replies
  • 203 views
i want to off set a raster by half cell size in XY so points created from it will be at the pixel center rather than the lower left hand corner. How can i expose these values so they don't have to be manually typed in?
the import format is ASCII grid so the information is right there in the header
ncols 200
nrows 200
xllcorner 220000
yllcorner 70000
cellsize 50
Best answer by takashi
Hi @jamiefinney, the RasterPropertyExtractor might help you. Check the _spacing_x, _spacing_y attributes which will be extracted by the transformer.
  • March 18, 2016
  • March 18, 2016
@takashi Thank you for that i knew there had to be that function in there somewhere.
  • March 18, 2016
@takashi how would i transfer these values into an offsetter transformer.
i getting errors when i try to add this into my model
either that the offset variable isn't a float value - @Value(_spacing_x)/2
or that the raster is being routed through the model and causing an error as a raster can't be exported as a mapinfo tab file.
  • March 18, 2016
@jamiefinney, insert the RasterPropertyExtrastor between the reader and RasterCellCoercer, and set "Yes" to the "Preserve Attributes" parameter of the RasterCellCoercer.
  • March 18, 2016
You can also offset the raster before coercing.
mark2atsafe
Forum|alt.badge.img+59
  • March 18, 2016
You could use the RasterCellOriginSetter transformer, and set it to 0.5,0.5 - then the cell origin would be the centre of the cell and you wouldn't need the Offsetter.
So, just :
  1. RasterCellOriginSetter
  2. RasterCellCoercer
  3. AttributeCreator
  4. Tiler... etc
I think that would be the most appropriate way, and quicker too.
  • March 22, 2016
Hi @jamiefinney, I answered straightly to your question - i.e. how to extract raster cell size. However, I agree with @Mark2AtSafe. The RasterCellOriginSetter would be the most efficient way, if you need to extract center points for each cell of an ASCII grid raster.
jdh
Forum|alt.badge.img+41
  • March 22, 2016
So, just :
  3. AttributeCreator
  4. Tiler... etc
This method has the added benefit that it works regardless of the original cell origin, whereas the offsetter method requires the ascii grid to be in the xllcorner instead of xllcenter format.
  • March 22, 2016
So, just :
  3. AttributeCreator
  4. Tiler... etc
@Mark2AtSafe good idea thanks for that - seems like a much more efficient way.
