Extract polygon with certain width
  • Feb 7, 2018 6:25 PM UTC
  • 5 replies
  • 202 views
sunhenry617
I need help with ideas on how to extract areas where the width >=1.1m within a polygon. I have attached a file (file geodatabase) here for anyone who wants to give it a shot. It is a long and skinny polygon reflecting sidewalks with curb and gutter all connected together in reality.
I have a solution working okay for a small number of such polygons. But it is not working efficiently enough for a large number of records. I have a total of more than 20,000 records to be processed.
Please share your thoughts.
Thanks!
Best answer by nathanatsafe
Hi @sunhenry617, thanks for posting your question!
I think I found a possible solution. I'm not sure it will scale up easily to 20,000 records, but it is not that complex. Hopefully this gives the desired/correct result, and if not at least l provides you something to work from.
Best,
Nathan
widthfinder.fmwt
nathanatsafe
Forum|alt.badge.img+9
  • Feb 9, 2018 1:04 AM UTC
Best,
Nathan
widthfinder.fmwt
sunhenry617
  • Feb 9, 2018 8:50 PM UTC
Best,
Nathan
widthfinder.fmwt
Thank you so much, @NathanAtSafe! You method is way way faster and better than mine. I am sure it won't take too long to process all of my data.
Cheers,
Henry
  • Jul 9, 2021 1:45 PM UTC
Best,
Nathan
widthfinder.fmwt
Hi Nathanatsafe,
I like to see if widthfinder.fmwt works for me. Could you send it to me? Thanks in advance! Best, Herman
nathanatsafe
Hi Nathanatsafe,
Hi @hdhaan​ ,
Here is the widthfinder.fmwt. Hope it helps!
Best,
Nathan
  • Jul 9, 2021 2:19 PM UTC
Thanks! Best, Herman
