Extract point cloud boundary and create 3D solid
  • Nov 3, 2017 10:45 AM UTC
  • 288 views
I have a point cloud and am wanting to create a 3D solid from the extents. I have been able to produce a solid like this below with help but just wondering if there is a way so that the solid is created like the first image attached with the solid that I require very roughly outlined in red?
Any help greatly appreciated
  • Nov 3, 2017 12:42 PM UTC
Hi @samstibbs73, a possible way I can think of is:
  1. PointCloudCoercer (Output Geometry: Single Multipoint): Transform the point cloud to a single multipoint.
  2. BoundsExtractor: Extract _zmin and _zmax of the multipoint feature.
  3. BoundingBoxReplacer (Replace With: Oriented Bounding Box): Transform the multipoint to an oriented bounding box.
  4. 3DForcer (Elevation: _zmin): Set _zmin as z-coordinate to the bounding box.
  5. Extruder (Distance: @Value(_zmax)-@Value(_zmin)): Transform the bounding box to a solid.
Hi @takashi, I get the error that I am out memory when following this? Any ideas on how I can resolve this?
  • Nov 6, 2017 1:40 PM UTC
Possibly the data size is too large to transform it to a multipoint feature. How about using the PointCloudThinner to reduce the number of points before coercing?
