Extract exterior box of IFC 3D model
  • May 25, 2022 10:42 AM UTC
  • 186 views
I would like to extract exterior box of my ifc file and remove all interior element and i didn't find the right transformers to do this.
birgit
Forum|alt.badge.img+25
  • May 25, 2022 1:45 PM UTC
It really depends on if your IFC contains an existing bounding box shape you want to extract or if you want to make a new bounding box. If you want to make a new bounding box you can use the BoundingBoxReplacer and set the "Replace with" setting to 3D Bounding Cube.
Thank you for your reply. Indeed, I tested this transformer but it creates a whole cube which is not correct
birgit
  • May 25, 2022 3:34 PM UTC
That is correct, it is a bounding box. I see you are converting your geometry into a pointcloud, is there a reason to do that? (or did the bounding box replacer not work on your geometry type?)
Apparently there is a new transformer in FME 2022(or downloadable on the FME hub for older FME versions) named SolidDissolver which might be able to combine all your geometry into 1 feature but I suspect that this transformer might be very particular with the geometry types it accepts.
Another option is to create a collection with an aggregator but features that are inside another feature will continue to exist making it kind of messy, but it is easy to generate
Your question is a difficult one because I think FME is still struggling with 3D Geometry Boolean operations but maybe somebody else has another idea.
  • May 31, 2022 10:29 AM UTC
Thank you for your answer, however for the old screenshot I followed an answer from someone who advised to go through the point clouds but it did not work. Testing the new transformer here is the error message that tells me.
