Extract data from SOAP XML,
  • Oct 10, 2023 8:06 AM UTC
  • 10 replies
  • 252 views
keller
Forum|alt.badge.img+7
how can i extract the attributes [Equipment-ID, Cleint-ID, Height and Date] from this xml? Any help will be highly appreciated.
Kind regards,
Keller.
Best answer by ebygomm
Using the xml that @oscard​  has posted
XMLFragmenter to  with Elements to Match set to Object to get a feature per object
XMLXQueryExtractor with the following Xquery
declare namespace x='http://tempuri.org/';
let $p := //x:Property
for $i in $p
return (
fme:set-attribute($i/@Name/string(),$i/@Value/string())
Then expose the relevant attributes
oscard
Forum|alt.badge.img+23
  • Oct 10, 2023 8:13 AM UTC
If the XML is well formatted you could use an XMLFragmenter with "Elements to Match" = Data.
And then a XMLFlattener with Elements to Match = Equipment-ID, Cleint-ID, Height and Date. You will need to expose those attributes in the Attributes to Expose, too.
PS: For some reason, the XML you have posted can't be properly parsed in my Notepad++. That could be an issue with my Notepad++ or an issue of the SOAP service you are using.
keller
  • Oct 10, 2023 8:50 AM UTC
Hello @oscard​ many thanks for the answer, i have tried flattening and exposing based on tutorials on the same topic but i get no data, here is the same xml using notepad+++
Thanks,
Keller.
oscard
  • Oct 10, 2023 9:12 AM UTC
Thanks,
Keller.
There is an encoding issue with that XML. I guess the first step should be solving that and then try to extract data.
Let me see if I can think of something or maybe someone else knows how to tackle this problem.
The XML should look like this:
oscard
  • Oct 10, 2023 9:58 AM UTC
This issue is more complex than I was expecting and it's a bit out of my league.
I've attached a workspace where I at least help you with the formatting and extracting of the Object nodes (where the attributes you want reside).
I think you need an XQuery to extract the properties into attributes, but that is something I have no idea how to do.
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/xmlxqueryextractor.htm
keller
  • Oct 10, 2023 10:52 AM UTC
Many thanks @oscard​ , I will keep looking around.
With regards,
Keller.
nielsgerrits
Forum|alt.badge.img+67
I can parse this, but not in an elegant way. What I did:
  • Read it as text.
  • Replaced &lt; and &gt; with < and > using the TextDecoder set to HTML.
  • Fragmented and flattened on Envelope/Body/ExportDataResponse/ExportDataResult/Data/Object
  • Exploded the list with properties to features.
  • Created attributes from Name and Value.
  • Merged to original object.
keller
  • Oct 10, 2023 11:59 AM UTC
  • Read it as text.
Thanks @nielsgerrits​ going to try it right away.
keller
  • Oct 10, 2023 12:22 PM UTC
Hi @jdh​ ,@Takashi Iijima​ , in another question i saw you guys helped out with the same problem(https://community.safe.com/s/question/0D54Q000080hfJ2SAl/extract-attributes-from-xml-attribute), i have tried following the answers but i seem not to get the same result. any idea of how i can extract the Property Names and Values only(in bold)? (It was a SOAP XML then fragmented and formarted it.Here is the XML.
Regards,
Keller.
<?xml version="1.0" encoding="UTF-8"?>
<Data>
   <Object Type="ProcessFunctionMeasurementPointValue" Action="InsertOrUpdate">
      <Property Name="Equipment-ID" Value="B0000481"></Property>
      <Property Name="Client-ID" Value="029772"></Property>
      <Property Name="Height" Value="16.04"></Property>
      <Property Name="Date" Value="2023-03-27T15:17:00+02:00"></Property>
   </Object>
      <Property Name="Height" Value="1604.00"></Property>
      <Property Name="Date" Value="2023-03-14T16:58:00+01:00"></Property>
   </Object>
</Data>
Forum|alt.badge.img+54
  • Oct 10, 2023 12:50 PM UTC
for $i in $p
return (
  • Oct 21, 2023 4:16 PM UTC
Regards,
Keller.
<Data>
   </Object>
   </Object>
</Data>
Hi @keller​ ,
Here is another solution.
You can convert the source XML you posted at first to a JSON document with XMLXQueryExtractor, and then extract required attributes with JSONFragmenter.
See the attached workspace example to learn more.
parse_xml_as_json XQuery Expression
declare namespace temp="http://tempuri.org/";
    for $x in parse-xml(//temp:ExportDataResult/text())//Object
    return
            "Type" : data($x/@Type),
            "Action" : data($x/@Action)
        for $p in $x/Property
        return { data($p/@Name) : data($p/@Value) }
Resulting JSON Document
      "Type" : "ProcessFunctionMeasurementPointValue",
      "Action" : "InsertOrUpdate",
      "Equipment-ID" : "ST0000481",
      "Client-ID" : "029772",
      "Height" : "16.04",
      "Date" : "2023-03-27T15:17:00+02:00"
      "Height" : "1604.00",
      "Date" : "2023-03-14T16:58:00+01:00"
