extract centerline from 3dsolids?
  • Oct 31, 2016 3:33 PM UTC
  • 6 replies
  • 366 views
franco69
Forum|alt.badge.img+11
Hi Guys,
I've attached a screenhot......a lot of Pipelines as 3dsolids from AUTOCAD3D.......is there any possibility to get the centerlines as a 2D polyline?
I know I wrote nothing but details because I want to know first if there is any possibility to do this in FME and write it in .pod file?
Greetz
Franco
franco69
  • Nov 3, 2016 12:17 PM UTC
Hi Guys again,
ok...start again with a selected cylinder ......screenshot.....any ideas or mathematic operations to calculate the middle point front and back to build a centerline from this solid?
any ideas?
Greetz
Franco
franco69
  • Nov 4, 2016 10:00 AM UTC
Hi Guys again,
i could produce the centerpoint from front circle and centerpoint from back circle.....
two points with XYZ Coordinate...but when i take the PointConnector to build the line the result is a 2DLine
and the length is wrong so.
How can i now produce a 3D line?
Greetz
Franco
franco69
  • Nov 4, 2016 10:08 AM UTC
or is the line 3D and the Lengthcalculator calculates only 2D?
Any thoughts? solutions?
Thx and Greetz
Franco
franco69
  • Nov 4, 2016 10:12 AM UTC
Hi Guys,
I solved it.....the line was 3D...I didn't check the length dimension button in the Lengthcalculator
Thx anyway
Franco
zzupljanin
Forum|alt.badge.img+5
  • Nov 4, 2016 11:39 AM UTC
Glad that you solved this. Though, I don't think that's applicable for elbow segment of pipeline (1st picture). Can you tell us how you solved that... It seems like heavy work for those parts.
franco69
  • Nov 7, 2016 7:53 AM UTC
you are right becaus eof the elbows......but i need only an intersection angle line there not exactly the curved line.....
Greetz
Franco
