Extend line to the point of intersection
  • Nov 9, 2017 4:06 PM UTC
  • 115 views
Hi. How I can extend line to the point of intersection?
THis is how it look now.
I wont from the connected line to make polygon.
Thanks!
fmelizard
Forum|alt.badge.img+22
  • Nov 9, 2017 4:10 PM UTC
Hi @mmmxxxm, I would recommend checking out the AnchoredSnapper. See the documentation here.
deanhowell
Forum|alt.badge.img+24
  • May 16, 2019 10:54 PM UTC
Did you ever find a solution to your issue as I have the same problem but need the actual bearing of the lines to remain the same and just extend until the point of intersection.
jdh
Forum|alt.badge.img+41
  • May 17, 2019 3:03 PM UTC
The simplest solution would be to use the lineExtender and then an intersector and then drop the overshoots.
