Exporting data to FME
  • September 13, 2013
  • 47 views
How to export the data from smallworld to Auto CAD using FME with attribute data? Can any one please suggest me in this regard.
fmelizard
Forum|alt.badge.img+22
You can try to generate a workspace (file >new> generate workspace) smallworld to dwg.
In the dwg writer parameters set the attribute output on extended entity data.
This is the most simple automatic translation you can do, from here on you can start making it as complex as you want.
Hope this helps,
Itay
davideagle
Forum|alt.badge.img+21
Bobby - You'll need to ensure you have the appropriate 'edition' of FME first. To do this you'll need the Smallworld Edition and I'd also recommend reviewing the detail here about the different readers/writers available for Smallworld http://fmepedia.safe.com/articles/FAQ/FME-Smallworld-configuration-options.
I'd highly recommend you get in touch with Ryan Cauffman at Spatial Business Systems Inc for a discussion. You can reach him at ryan.cauffman@spatialbiz.com.
