Export multipolygons into a GeoPackage
jugoslaviaa
I have a workbench which takes two inputs - both are polygons. One clips the other one. After clipping I use aggregator to aggregate the polygons with same attribute and the output i want to write into a gpkg file as multipolygon. The workbench works perfectly if i write single geometry to gpkg or if i write multipolygon into shp. However it is not working with mutlipolygon in gpkg. I have tried many things which were suggested in the forum. But nothing helped so far.
Please let me know any ideas. I am out of ideas
  • July 14, 2023
It might be helpful if you could post a minimal workspace template there that makes it possible to reproduce the issue.
jugoslaviaa
  • July 14, 2023
Sure but how do I do that with my input data? I mean how can i upload the template with the data or sample data
  • July 14, 2023
Have a look here: https://community.safe.com/s/article/what-is-the-best-way-to-share-my-workspace-and-dat
Forum|alt.badge.img+39
  • July 14, 2023
"However it is not working with mutlipolygon in gpkg"
How is it not working? Is the workspace failing, if so are there any warnings or error messages? Is the geopackage getting created but does not contain the expected data? Are you getting individual polygons instead of multipolygons
You are using Table Handling 'Create if Needed' - if you are trying to write multipolygon data to an existing table that initially was created with geometry set to geopackage_polygon the setting in the writer won't be used and the polygons will be deaggregated on writing.
jugoslaviaa
  • July 14, 2023
There is no error whatsoever. But the final gpkg data has only the attribute of the features without geometry.
jugoslaviaa
  • July 14, 2023
So I created a minimal workbench and there the problem does not accure. I wrote the results after clip in the original workbench and I copied the rest and it is working. If you compare minimal workbench with the orginal, the output of the deaggregator is different although input is the same.. I dont get it.
