Export LandXML without creating parcels?
  • Sep 23, 2024 10:44 AM UTC
  • 0 replies
  • 63 views
davidlindvall4
Observer
Hello,
I’m using the LandXML writer to export a surface. However, FME creates two Parcels, in addition to the surface (that i created based on a point cloud). These Parcels cause problems when trying to import the surface into some software. Civil 3D works fine, since it support Parcels, but for other software it does not work. Is there a way to NOT create parcels when exporting the LandXML?
