export format
  • December 16, 2014
  • 41 views
I created a workflow to:
1) Connect to ArcSDE (Oracle)
2) Read a table
3) Export the table data to CSV.
The data is exported, but the formatting is a problem.
I have a fields
  • UPRN this is a char/text field with numbers eg: 010000000, or 102000000               Exported as 1.E+11
  • Date fields        Exported as 2.01E+13
Tried chaning output field to text and char in the model.
What is the easiest way to sort out the formatting??
Thanks,
Clive
fmelizard
Forum|alt.badge.img+22
  • December 16, 2014
Have you tried the dateformatter? and the stringformatter (set on s) for the non date attributes?
gio
Forum|alt.badge.img+15
  • December 17, 2014
StringFormatter.
 Or [format] (tcl) in attribute creator
