Export attributes to a word table?
  • Aug 21, 2020 3:13 PM UTC
  • 6 replies
  • 260 views
Hi, everyone
I wanna export attributes to a word table, so I use MSWordStyler transformer to generate a table element before writing into a Word writer. The pic below shows how MSWordStyler's parameters are set.
捕获
However, when I run the workspace I got a error says that "Error message: 'AttributeError: 'unicode' object has no attribute 'append'".
Is there something I miss or somthing set incorrectly? What should I do to deal with it?💗
srg
Forum|alt.badge.img+10
  • Aug 24, 2020 11:10 AM UTC
@moye​ Can you provide more details on the Writer you are using?
  • Aug 24, 2020 1:33 PM UTC
Thank you @Raghavendran S​ for your reply~
The writer I am using is a common writer I created by clicking Add Writer button in the toolbar.
I set the format parameter to Microsoft Word and specified the saving location.
The whole thing I want to do is reading attributes from a ArcGIS mdb file, and then exporting these attributes to a Word table.
To achieve that, I used a ArcGIS mdb reader to extract attributes, and I used a MSWordStyler to convert all the attributes to table format,
I used a Microsoft Word writer to generate a document and store the content.It was so simple that it should have succeeded, however I got a issue at last.
I asked my colleague for help and I ran my workspace in his PC. The workspace behaved normally which is out of my expections. After consulting to my colleague, I finally figured it out that the MSWordStyler transformer is incompatible with FME Desktop 2019, and is compatible with FME Desktop 2018. I'm not sure my hypothe sis is right or not.
Forum|alt.badge.img+54
  • Aug 24, 2020 1:47 PM UTC
The MSWordStyler definitely works with FME Desktop 2019.2.2.0 (Build 19823)
  • Aug 24, 2020 3:45 PM UTC
I dont know, mine (Build 19092) doesn't work.😂 ​
debbiatsafe
Forum|alt.badge.img+24
Hi @moye​
Build 19092 should be a Beta release of FME 2019.0.
I tested creating tables with the MSWordStyler along with the Word writer and did not encounter any issues using builds 19238 and 19253. Are you able to upgrade to the latest official release of FME or try using an official released version of FME 2019? You can find our past installers here.
  • Aug 24, 2020 11:53 PM UTC
Hi @moye​
I will try it, thank you very much @debbiatsafe​ ​
