Exploding a multi-nested XML file using XMLFragmenter to build a lookup table
  • Dec 6, 2019 2:43 PM UTC
  • 266 views
salvaleonrp
Forum|alt.badge.img+23
I can't seem to line up my elements/attributes on this lookup table I'm creating. Thanks in advance!
Below is the screenshot of the XML attribute I'd like to create a feature from.
Below is the parent-children tree of the elements I want to retrieve from my XML file.
This is the screenshot of my workspace and configuration. Enable Flatenning is checked and all options are default.
This is the result I'm getting from the workbench
Below is the expected result
DomainNetworkName
networkSourceId
NetworkSourceName
AssetGroupCode
AssetGroupName
AssetTypeCode
AssetTypeName
ElectricDistribution
6
ElectricDistributionDevice
1
Arrester
1
Distribution Class
6
2
Breaker
1
Air Powered
6
3
Capacitor
1
Fixed Capacitor
6
4
Circuit Breaker
1
Air Powered
6
5
Elbow
1
Load Break
6
6
Fuse
1
Automatic Sectionalizing
7
ElectricDistributionLine
3
Low Voltage
1
Overhead
7
1
Busbar
1
Busbar
7
4
Medium Voltage
1
Single-phase Overhead
7
6
Subtransmission
1
Overhead
9
ElectricDistributionJunction
3
Ground
1
Neutral Ground
ElectricTransmission
11
ElectricTransmissionDevice
3
Circuit Breaker
1
Circuit Breaker
11
6
Line Monitor
1
Line Monitor
11
11
Transformer
1
Transformer
11
13
Capacitor
1
Fixed Capacitor
12
ElectricTransmissionLine
2
Connector
1
Connector
12
3
High Voltage AC
1
High Voltage AC
14
ElectricTransmissionJunction
1
Connection Point
1
14
3
Ground
1
Neutral Ground
Best answer by salvaleonrp
Problem solved. Results below.
For problem 1, the key was the XML-Parent-ID of the child elements AssetGroups. By separating the rejected output port for the three DomainNetwork values and merging it later with the elements of the AssetGroup and AssetType I was able to populate the DomainID and DomainNetwork values from the attribute merge of the FeatureMerger. My second issue was merely AssetGroups that do not have AssetTypes. After making a sort on the XML-ID the pattern became quite obvious.
Screenshot of final translation below.
Yesterday, I found the network services DE in REST so I'm going to have a new version for that. The JSON on queryDataElements has more metadata.
jdh
Forum|alt.badge.img+41
  • Dec 6, 2019 3:25 PM UTC
My recommendation would be to set the Elements to Match to 'JunctionSource', in the flatten options, add the Ancestor Element (Grandparent). Then explode the AssetGroups/AssetTypes lists to get one feature per AssetType with all the necessary ancestor attributes.
salvaleonrp
  • Dec 6, 2019 10:11 PM UTC
Thanks for the suggestion @jdh. I'm a few more steps closer.
Here's the updated workbench with ListExploders.
I am getting there.
A couple of issues though.
1. DomainNetworkID and DomainNetworkName are missing even if I have the Grandparent enabled.
2. Where AssetGroup=0 and AssetType=0 are going to the rejecte port for MISSING_PARAMETR_LIST even if these features are in the tree?
salvaleonrp
  • Dec 12, 2019 2:42 PM UTC
