Exlude areas from DonutHoleExtractor?
  • Nov 7, 2018 1:27 PM UTC
  • 6 replies
  • 69 views
aron
Forum|alt.badge.img+16
I have a dataset with various depth zones that I am trying to process by running a DonutHoleExtractor, then removing some of the polygons that I don’t want based on certain rules and lastly rebuilding it all with a DonutBuilder. This works fine for the depth zones but some of the areas that are land, white in the maps below, get turned into depth zones. This is not surprising, but I would like to find a workaround. I looked at using the holes from the DHExtractor to punch holes in the last step, but the ”land holes” get the attribute data from their surrounding depth zone, so I have not found a way to single them out.
Any ideas to how exlude certain areas when extracting donuts? Or maybe you have a better idea for a workaround?
Please note that this is a follow up question to, https://knowledge.safe.com/questions/81896/selecting-square-ish-donuts.html
The brown map is the original data and the green one is after DonutHoleExtractor
Best answer by takashi
I think once you merged the original features into a single donut feature with the Dissolver, then you could extract only "land holes" with the DonutHoleExtractor.
  • Nov 7, 2018 2:06 PM UTC
aron
  • Nov 8, 2018 12:40 PM UTC
Hi @takashi,
Thanks! Your method does the job of finding the "land holes". Unfortunatly I can't seem to get the results I want when adding these new "holes" to the final DonutBuider. It punches out more than I want. I tried doing it in two steps but then I got even stranger results. Is there some way to select what data to punch out? I am guessing it could be done by grouping? If so, how is it done? Or is there an other way?
  • Nov 8, 2018 4:26 PM UTC
If I understood your requirement correctly, this workflow would generate your desired result.
  1. Extract outer shells from all the original donut features with the DonutHoleExtractor.
  2. Remove some of them based on certain rules.
  3. Re-build donuts from the remaining polygons with the DonutBuilder (Drop Holes: No).
  4. Count the number of holes for each feature with the HoleCounter.
  5. Send features with no holes and the "land holes" (created on another data flow with the method I suggested above) to another DonutBuilder (Drop Holes: Yes).
aron
  • Nov 9, 2018 8:15 AM UTC
Thanks! That will do the job!
aron
  • Nov 22, 2018 12:20 PM UTC
Hi @takashi,
I have unfortunately not been able to get this to work. The problem is that some of the areas that have holes need another punch-out from the "land holes". So it does not work by filtering out areas with no holes. I am sure there is some clever workaround, but I have not been able to figure it out. Any ideas to how I could get it to work?
I attached my Workbench and some example data for anyone interested in seeing where it goes wrong.
Depth zones.zip
  • Nov 22, 2018 3:12 PM UTC
Hi @takashi,
Depth zones.zip
There are small polygons whose number of coordinates is 5 or less. Most of them are holes of donuts, but some of them are independent polygons overlapped other large one. If the requirement was to remove all the small polygons from the dataset, this workflow might work for you.
