Excel writer appears to terminate the process
  • Oct 7, 2026 9:55 AM UTC
  • 72 views
ryoung
Hello,
with the upgrade to version 2026.1.2.0 I have run into a strange behaviour when using Excel writers.
FME Workbench simply says at the end:
FME was unable to finish the workspace translation due to an unexpected termination. Any data caches will be cleared because their data integrity is compromised.
This is currently not much to work with.
For pinpointing the cause, I deactivated all excel-writers in my workbench and it just ran fine.
Has anybode experienced this with Version 2026.1.2.0?
Kind regards,
Ryoung
danilo_fme
Forum|alt.badge.img+58
  • Oct 7, 2026 2:23 PM UTC
​@ryoung Hi,
Please, could you send us the template file (fmwt)?
Thanks in Advance,
runneals
Forum|alt.badge.img+32
  • Oct 12, 2026 3:30 PM UTC
We are also seeing this error message on a LineOnLineOverlayer in 2026.3. We can get it to run when we run the workspace to the transformer before the LineOnLineOverlayer, and then run it to the LineOnLineOverlayer, but not all at the same time.
In Windows Event Viewer, we’re seeing the following Error:
Faulting application name: fme.exe, version: 2026.7.57.26589, time stamp: 0x6a978634
Faulting module name: KERNELBASE.dll, version: 10.0.26100.33438, time stamp: 0xace796d3
Exception code: 0xebf00bab
Fault offset: 0x00000000000c75fa
Faulting process id: 0x158C
Faulting application start time: 0x1DD5A5AA603237C
Faulting application path: C:\Program Files\FME\fme.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report Id: 6cf978bc-83ec-4000-acd1-f2568452f288
Faulting package full name:
Faulting package-relative application ID:
Note this does seem to be a bug introduced in 2026.3, as we just installed and ran it on the same machine in 2026.2.1.1 without any issues.
DanAtSafe
Forum|alt.badge.img+23
  • Oct 12, 2026 11:46 PM UTC
​@ryoung and ​@runneals Please submit tickets for these problems via https://support.safe.com/hc/en-us/p/Support Thanks!
