Excel output with a cell that contains a picklist.
  • Jun 6, 2023 3:05 PM UTC
  • 49 views
I would like to output an excel template with one of the columns having cells containing values from a pick list.
From my understanding I don't think FME is able to output the picklist, but a possible solution is to have the pick list already defined in the excel template.
However, even if I have the cell defined, I do not know how to have it replicated for each row that is outputted from the FME template. Do I have to just fill the entire column with the picklist and than delete the extra rows after the fme template is run or is there a more elegant solution.
Thanks
hkingsbury
Forum|alt.badge.img+73
  • Jun 7, 2023 8:48 PM UTC
for your template, if you follow the following guide, you can create a dynamic picklist.
https://www.excelcampus.com/tips/dynamic-data-validation/
Then in FME you'll need to update the table/column with the new values you need in your picklist
