EsriReprojector problem
  • Aug 3, 2017 3:37 PM UTC
  • 8 replies
  • 109 views
When I use the EsriReprojector converter, FME can't recognize my custom Esir geographical conversion method. How can I solve this problem?
Best answer by bruceharold
Hi
If you create a custom geographic transformation method and give it a name you can use the name in EsriReprojector.
Hi @dianlu5,
I think that this article may be a good place to start. For more information on custom coordinate systems and how to add them in FME, please check out this article as well as our documentation on this topic. If you run into issues with this process, please let us know!
  • Aug 4, 2017 2:33 AM UTC
I need to use my 7 parameter to do the coordinate conversion. The conversion method has been defined in Arcgis, but FME is still not recognized
  • Aug 4, 2017 2:35 AM UTC
Hi @dianlu5,
bruceharold
Forum|alt.badge.img+20
  • Aug 4, 2017 2:16 PM UTC
Hi @dianlu5,
Hi
bruceharold
Hi
  • Aug 5, 2017 7:09 AM UTC
Hi
I have try,but failed
bruceharold
  • Aug 7, 2017 4:42 PM UTC
Hi
If your problem is related to the syntax for a 7-parameter adjustment with the Esri tool please log a support call with Esri.
  • Have you solved your problem? I had the same problem.
