ESRI Utility network - Data models
  • Jan 4, 2019 11:49 AM UTC
  • 172 views
boubcher
Forum|alt.badge.img+11
Hello There
is it possible to get access to the GDB Schema of the utility network of Esri, without having An ArcGIS product
Thanks
  • Jan 4, 2019 12:21 PM UTC
If it's an SDE Geodatabase you can usually read directly from the underlying database (e.g. Oracle or SQL Server) using the relevant reader in FME.
However:
  • It may be difficult or tricky reading the geometries (hint: cast to WKB in a SELECT statement, if possible, then use the GeometryReplacer in FME to restore the geometry)
  • It may be difficult or complicated getting to SDE specific functionality, such as topology definitions, relationships, domains, etc.
boubcher
  • Jan 4, 2019 1:58 PM UTC
@david_r
My goal is to use the ESRI network utility schema in order to build a custom schema, how could we get ESRI schema, I thought its available like the inspire one.
  • Jan 4, 2019 2:05 PM UTC
@david_r
Ah, sorry, seems I misinterpreted your question then.
salvaleonrp
Forum|alt.badge.img+23
  • Apr 29, 2021 1:03 PM UTC
@david_r
This blog hints on how to get to the Utility Network Data element using REST API and JSON parsing.
https://www.esri.com/arcgis-blog/products/utility-network/data-management/exporting-subnetworks-using-data-interoperability/
If you take the SDE approach, then the GDB items table should be your start and this would require XML parsing. Blog supports UNv3 and I'll update into UNv5 and add a sidebar on how to get other UN and GDB properties like Attribute Rules.
