Esri ArcGIS Server Feature Service Writer not found
  • Mar 7, 2024 5:16 PM UTC
  • 154 views
jcasey
Forum|alt.badge.img+7
Hello. The WRITER called Esri ArcGIS Server Feature Service Writer does not seem to exist. The reader is there.. but not the writer
This is not AGOL and not Portal - just “Esri ArcGIS Server Feature Service Writer”
It’s in the documentation as existing and I do need to write out to an Esri ArcGIS Server feature service using a rest endpoint url
Please point me in the right direction if I’m missing it somehow. If it’s not there, why not? The documentation is at https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/arcgisfeatures/arcgisfeatures.htm
Thanks
Jim
hkingsbury
Forum|alt.badge.img+73
  • Mar 7, 2024 7:31 PM UTC
What version of FME are you using?
jcasey
  • Mar 8, 2024 4:05 AM UTC
2022.0. Our TS helpdesk has a ticket to update my version of FME. Hopefully that could resolve this? Not seeing the writer to download was puzzling even if I’m not at the latest version.
Thanks for the response!
nielsgerrits
Forum|alt.badge.img+67
This is a fairly new Writer, introduced in FME 2023. See New Formats in FME 2023+
jcasey
  • Mar 8, 2024 10:15 PM UTC
Thanks for the heads-up!  As soon as my FME app is updated by our Tech Services team (hopefully soon) … I’ll give it a try.
Thank you!
Jim
