Error writing blocks in Shape to DWG translation
  • June 20, 2016
  • 54 views
mamajid
Using dwgstyler in FME; I try to convert points from shp to dwg using a block for symbologie and I recieve this warning: Specified block 'C-E-TOP-NIV-PTC-SYM' is not defined in AutoCAD file. Skipping feature. Please advice!
  • June 20, 2016
Have you specified a template file in the parameters? If so does that named block next step in the template?
Also wondering if the DWGStyler has a different template file specified to the Writer template parameter.
