Error while performing a grid transformation
  • May 4, 2018 8:30 AM UTC
  • 5 replies
  • 140 views
lianaolianov
Forum|alt.badge.img+5
Hello,
I created a new coordinate system + transformation based on a grid .gsb file.
While using the Csmapreprojector the transformation fails, can someone help me to figure out the reason ?
Thank you very much.
Here is the transformation I defined
Here is the error I get :
CsmapReprojector_8(TeeFactory): CsmapReprojector_8: Reproject: Could not reproject the geometry of the preceding feature: Reprojector: Could not create reprojection engine
and here is the Csmapreprojector configuration
jneujens
  • May 4, 2018 9:43 AM UTC
Did you try to do it with other coordinate systems? Are does it always fail?
If you created this transformation I think you will have to share the file to know what is going wrong.
lianaolianov
  • May 4, 2018 9:48 AM UTC
Hello,
I've never tried with other another coordinate system
Here is the transformation file I created
trans.zip
  • May 4, 2018 10:18 AM UTC
I cannot find a coordinate system called "ITRF" in my Coordinate System Gallery. Is it a custom coordinate system that you defined?
lianaolianov
  • May 4, 2018 10:23 AM UTC
Yes it is a custom one I added
jneujens
  • May 9, 2018 2:32 PM UTC
lianaolianov, as far as I can check, I think all the necessary parameters are there.
You are 100% sure your custom coordinate system is error proof?
The NTv2 grid file you use to transform: are you sure it covers the coordinates being transformed?
If not, the transformation will not work.
You might try to add a 'FALLBACK' parameter in your transformation file. It will use a different transformation in case your .gsb file does not cover the coordinates being transformed. If you add this parameter and the transformation works, I think you have your problem?
More information on these parameters can be found here: http://docs.safe.com/fme/2017.1/html/FME_Desktop_Documentation/FME_Workbench/CoordSys/coord_sys_custom_transformation.htm
