Error when using GoogleCloudStorageConnector on MacOS
  • Mar 31, 2025 12:44 PM UTC
  • 131 views
philiqq
Forum|alt.badge.img+4
Since the last update of the GoogleCloudStorageConnector (on 26.03.2025, safe.google-cloud-storage [2.5.0]), it no longer works.
I always get this error message:
Message Type: fme::internal::_v0::py::Exception Python Exception <TypeError>: JSONConnection.api_request() got an unexpected keyword argument 'extra_api_info' Error encountered while calling method `input' GoogleCloudStorageConnector_CALLER (PythonFactory): PythonFactory failed to process feature
I am using FME 2025.0.0 with Python 3.13 on a macOS Sequoia (15.3.2).
Except of the transformer update nothing has been changed.
The error does not appear on Wondows with the same FME settings.
Best answer by nielsgerrits
I’m not sure if the forum is the best place to get this fixed. I would submit a ticket for this, as it is created by Safe. You could also try commenting on the FME Hub page, but I have no experience how quick the follow up is.
nielsgerrits
Forum|alt.badge.img+67
philiqq
  • Mar 31, 2025 1:27 PM UTC
Thank you for the tip. I didn’t know about thet. The ticket is a way better place to address this.
jbradfor
Forum|alt.badge.img+7
  • Apr 13, 2025 6:49 PM UTC
Wanted to let you know that comments are not allowed on hub for GCS 2.5 so I opened a ticket as well.  I reverted back to GCS 2.4.1 and it is working fine again.
