error when reprojecting data from mtm27-8 to wgs84.platecarree
  • August 25, 2016
  • 43 views
arthy
Forum|alt.badge.img+8
Hello,
I would like to reproject data with X,Y coordinates in mtm27-8 to WGS84.Plate Carree.
I'm getting an error message saying that the reprojector could not create the reprojection engine.
I have the input file (essai.xlsx) as well as the workspace (xlsx2txt.fmw).
Any thoughts?
Arthy
itay
Forum|alt.badge.img+19
  • August 25, 2016
Hi @arthy I have had a look at your workspace and you should report this issue to Safe, I got the following BAD NEWS....after trying several options to reproject the point data.
BADNEWS: CS-MAP Reprojector: No transformation found to get from 'MTM27-8 (NAD27)' to 'WGS84.PlateCarree (WGS84)'. Add CsmapReprojector tranformers with explicitly chosen transformations (csmapengine.cpp:1409) 2016-08-25 20:00:33| 0.3| 0.0|WARN |CS-MAP Reprojector: No transformation found to get from 'MTM27-8 (NAD27)' to 'WGS84.PlateCarree (WGS84)'. Add CsmapReprojector tranformers with explicitly chosen transformations 2016-08-25 20:00:33| 0.3| 0.0|ERROR |BADNEWS: Reprojector: Could not create reprojection engine (fmereprojector.cpp:398) 2016-08-25 20:00:33| 0.3| 0.0|WARN |Reprojector: Could not create reprojection engine
btw the Y value one of the PDQ 9 record is slighttly different to the rest..
arthy
  • August 29, 2016
@itay
I Had the following response from Safe:
In the Workbench menu, please pick Tools - FME Options - Coordinate Systems. In the Implicit Transformations, choose whether the NAD27 to NAD83 transformations should use Canada Only or USA Only grids.
In my case, I have to select Canada Only.
itay
  • August 29, 2016
@arthy Haha! so that why they ask you to choose this setting when installing !, thx for sharing I doubt i'll ever use these coordinate systems in my life time but who knows!
