Error : unique Attribute Names strings in the translation
  • Mar 10, 2022 11:13 AM UTC
  • 6 replies
  • 492 views
davekazemi
Forum|alt.badge.img+5
Error:
I have a workflow using a generic reader and it give me below warning:
2022-03-10 22:07:41| 135.3| 0.3|WARN |Detected 2600000 unique Attribute Names strings in the translation. Several unique names may result from operations like list attribute creation or feature type fanout. Reducing the number of unique names may improve translation performance and reduce memory usage
any idea what the reason is?
nielsgerrits
Forum|alt.badge.img+67
Never had this one. It looks like workbench is detecting a very high number of individual attributes which can negatively influence performance.
What data type are you reading?
davekazemi
  • Mar 11, 2022 5:42 PM UTC
I'm trying to read some different BIM model ifc,dgn and 12d in a generic reader,
@davekazemi​ is your reader creating many FME list{} attributes? That is often a cause for this WARN message.
hasant1973
Forum|alt.badge.img+3
  • Apr 27, 2023 12:22 PM UTC
Would be great to have a bit more detail with the message. For example what field and what transformer to look at. I'm also getting it and have no idea what to do. The only way to narrow it down is to deactivate parts of the workspace and see when it disappears and when it comes back.
klaas
Forum|alt.badge.img+12
  • May 23, 2024 9:38 AM UTC
Any solution to this atm?
BTW, I am reading an XML/OGC GML
helmoetz
Forum|alt.badge.img+18
  • Jun 11, 2025 10:03 AM UTC
Me too getting this message reading XML/GML, using XML (Extensible Markup Language) FeatureReader in dynamic mode, reading feature paths.
If I specify “one port per featuretype” in stead of “Single Output port”, the message does not show and the translation seems to run faster.
