Error sending SMTP email from Automation using Office365 account with MFA
  • Apr 19, 2023 12:57 PM UTC
  • 318 views
spatialcase
Hi, I am using the Email(Send) action within an Automation but am unable to get it to work.
I am using: smtp.office365.com on port 587 and StartTLS encryption.
The office365 email account has MFA enabled and so I am using an App password.
I am able to use the same configuration within the FME Desktop Emailer transformer just fine - but the same parameters do not work within the FME Cloud automation.
Error message is:
"com.microsoft.aad.msal4j.MsalInteractionRequiredException: AADSTS50126: Error validating credentials due to invalid username or password"
My FME Cloud instance is running "FME Server 2022.2.1 Build 22776 - linux-x64"
I have also supplied an App Client ID by registering an App within am Azure AD as described in this article but it does not resolve this issue:
https://community.safe.com/s/article/How-to-use-Microsoft-Modern-Authentication-with-FME#ForServer
Any Ideas?
Thanks
hkingsbury
Forum|alt.badge.img+73
  • Apr 19, 2023 11:54 PM UTC
You might need to look at producing an app password on 365 (assuming it supports that)
spatialcase
  • Apr 20, 2023 7:49 AM UTC
Thanks, but as mentioned above I am already using an App password. The settings that work fine in the Emailer Transformer do not work within the Automations Send Email action.
keziaatsafe
Forum|alt.badge.img+8
hkingsbury
  • Apr 21, 2023 1:29 AM UTC
Sorry, I missed that re the app password - seconding what Kezia has said below
