Error in PDF Writer name HOW to get it right ?
vimva679
Forum|alt.badge.img+9
I am trying to write PDF file using PDF writer, when I add @Value(Scan_Location) in fanout dataset it creates 2 different files as output. And that is not what i want .
I just want this name ….20240621 NI2-HK-L03 As-built_PDMS Comparison Report F1.pdf
and just one file
Best answer by redgeographics
No, that is not what I meant.
See those little green magnifying glasses? They’re feature caches, allowing you to inspect the data at any point in your process. That way you can check which of the 6 features coming out of the PDFPageFormatter do not have a timestamp (although, since they are in File1, I’m certain it’s those two rectangles. And looking at the filename it looks like they’re misssing a lot of other attributes as well.
So that’s what you need to find out and fix. I must say it’s very hard trying to help you if every screenshot seems to be from a different workspace.
Oh, and do a Rerun entire workspace, trust me on this one, timestamps are notoriously difficult when feature caching is on.
lambertus
Forum|alt.badge.img+16
  • June 21, 2024
Hi @vimva679, in this case you dont need a Fanout expression but just a normal path including your pdf file name. How about this one:
Normally I dont use PDF writers but this looks okay for your solution. It turns out red for now because the file path is not available on my desktop of course.
vimva679
  • June 21, 2024
@lambertus thank you am not sure as the Scan location is dynamic value , so whatever is in scan location its should write that as file name .
lambertus
  • June 21, 2024
@vimva679 yes valid question, I updated my answer :) See above, I included Scan location and Timestamp as variables into the filename.
Be aware that the filename includes spaces right now, that can lead to an error probably
vimva679
  • June 21, 2024
@lambertus nops it still creates 3 files
vimva679
  • June 21, 2024
vimva679
  • June 21, 2024
I found a workaround with User parameter
@Value(_timestamp) $(Scan_Location) As-built_PDMS Comparison Report $(FieldView_Number).pdf
thank you @lambertus so much :)
lambertus
  • June 21, 2024
You're welcome :)
You got 3 files by the way as output because you connected 3 lines with the FeatureWriter as separate inputs which will create 3 output files.
In case you want just one file, create first the right output file with the transformers you need, then connect this output with one line to the FeatureWriter
vimva679
  • June 21, 2024
I think am not getting it right , when i tried to rerun report with same setting , it generates error
i am having just one port connected and having Path as then below is report looking like
PDF report 1
C:\Users\vVaghani\Downloads\FME\10_PDMS_LST_Report_AI\03_Output_Data\@Value(_timestamp) @Value(Scan_Location) As-built_PDMS Comparison Report $(FieldView_Number).pdf
PDF report 2
C:\Users\vVaghani\Downloads\FME\10_PDMS_LST_Report_AI\03_Output_Data\@Value(_timestamp) As-built_PDMS Comparison Report $(FieldView_Number).pdf
vimva679
  • June 21, 2024
@daveatsafe Any idea why its not writing correct file name
daveatsafe
Forum|alt.badge.img+19
  • June 21, 2024
It seems to me that you may have two different values in the data for attribute ‘Scan Location’, so the data is being output to two different PDF files. I would recommend switching to an attribute whose value is consistent within the entire dataset, or ensuring that Scan Location consistent within the entire dataset.
One way to do this is to use a Sampler to separate the first feature from the rest, then use a VariableSetter to store the value of Scan Location. Send the rest of the features through a VariableRetriever to get the first feature’s Scan Location.
vimva679
  • June 24, 2024
Thanks @daveatsafe not quite well , i tried using single input as well and it still create 2 PDF output, 1 blank and another with statistics.
I think its got some issue with PDFPageFormatter
Forum|alt.badge.img+50
Are you sure all your features are getting a timestamp (and all of them are getting the same timestamp)?
vimva679
  • June 24, 2024
Here is test data and FME workbench test attached. Maybe you could have better insight @redgeographics @daveatsafe @lambertus
vimva679
  • June 24, 2024
I have tested it and come to conclusion that it is Creator instance that is causing problem or faulty ….highly appreciate with any workaround or suggestion
As I said earlier:
“Are you sure all your features are getting a timestamp (and all of them are getting the same timestamp)?”
If all the features going into the PDFPageFormatter have a timestamp -except- the one coming in from the Creator and you use that timestamp as part of your output file name you are indeed going to get two separate output files. Scroll up to your post from 2 days ago where you are showing 3 PDF files. The one selected does not have a timestamp in its name.
So check that. Inspect the output from 2C_db (which transformer is that anyway?) and see if it has a timestamp attribute.
And if you find that it doesn’t then you’ll need to make sure the timestamp gets added to all features you want to write to PDF. One way to do that is to use a bit of Python code in a scripted parameter, there was a post just last week by @nielsgerrits about exactly that.
vimva679
  • June 24, 2024
yes all of them are getting the same timestamps and I have tested with both with and without timestamps , it still generates 2 files :(
Can you show me that the output of 2C_db has a timestamp?
vimva679
  • June 24, 2024
I believe this is what you meant ?
 the result is 2 files
File 1
File 2
  • June 24, 2024
vimva679
  • June 24, 2024
:(  yes that true timestamps are horrible .It doesn’t get any closer in either all ways
vimva679
  • June 24, 2024
I think i found solution ...here is it how it will work …...atleast 1 column common that contains the same information :)
vimva679
  • June 24, 2024
here is working FME workbench for community users, its perfectly working :)
