Error in JSONTemplater
danilo_fme
Forum|alt.badge.img+57
Hello all,
I tried to use the transformer JSONTemplater but my log file shows a error:
WARN  |JSONTemplater_2(XMLTemplaterFactory): The following error occurred near line 1, column 14 of the query:
2016-06-27 11:03:12|   1.4|  0.0|WARN  |JSONTemplater_2(XMLTemplaterFactory): invalid expression: syntax error, unexpected ExprSingle (missing comma "," between expressions?)
My configuration:
atendimentos:[{
                                  "status":fme:get-attribute("Status"),
                                  "regiao":fme:get-attribute("regiao"),
                                  "numserv":fme:get-attribute("numserv"),
                                  "label_veiculo":fme:get-attribute("label_veiculo"),
                                  "placa":fme:get-attribute("placa"),
                                  "dh_aciona":fme:get-attribute("dh_aciona"),
                                  "tipo_serv ":fme:get-attribute("tipo_serv"),
                                  "ident_turma":fme:get-attribute("ident_turma"),
                                  "dh_designa":fme:get-attribute("dh_designa"),
                                  "latitude":fme:get-attribute("latitude"),
                                  "longitude":fme:get-attribute("longitude"),
                                  "id_abrangencia":fme:get-attribute("id_abrangencia"),
                                  "precisao_calculada":fme:get-attribute("previsao_calculada")
Thanks in Advance,
Hi @danilo_inovacao, I found two issues in your expression.
  • The entire JSON object should be surrounded by curly brackets {}.
  • Name of a JSON object/array should be surrounded by double quotations.
Try modifying the expression, like this.
    "atendimentos":[{
danilo_fme
  • June 27, 2016
    "atendimentos":[{
thanks a lot @takashi :)
Its works!
