Error duplicate key on PUT with FeatureWriter
  • Oct 15, 2022 6:02 AM UTC
  • 68 views
pg.souque
I want to insert or replace a json document in a collection using PUT and mongodb_id with a Featurewriter.
If the document don't exists, no probleme
If the document exist, there is an errror message:
E11000 duplicate key error collection: fdppma_dev_pdpg.Couche index: _id_ dup key: { : ObjectId('62b01e134c2300007e0001a5') }: generic server error
I believe that Put delete the object before insert it.
Someone have got an idea ?
Thanks
kailinatsafe
Forum|alt.badge.img+24
Hello @pg.souque​, thanks for posting! Would you be able to share a bit more information about:
  • What version of FME you're using?
  • What data formats you're reading/writing to?
  • What tool are you using to make the updates? (eg. where is PUT statement being used?)
  • A full logfile?
If you're able to share a smaller workspace where I can reproduce the error, that would be great! Otherwise, it might be helpful to know how your FME workbench is currently set up? (screenshot would suffice). Happy to help, Kailin
pg.souque
  • Oct 19, 2022 6:57 AM UTC
Hi @kailinatsafe​ ,
  • Fme version: FME(R) 2022.0.1.1 (20220617 - Build 22350 - WIN64)
  • Data format : Json to a mongodb collection
  • Update with Featurewriter (see attachment)
  • log: error at 2022-10-19 08:28:33 (can i send to you the entire log by mail ?) :
  •  Attributes: only a json and mongodb_id
Thank you
FeatureWriter jsonEnd of Workbench
