Error: “DEFAULT_MACRO line in file D:\\wb-xlate-1420804135324_16692 has no macro name on it”,
  • January 9, 2015
  • 25 views
jamal
Forum|alt.badge.img+5
I wanted to run my workbench as usual but I got the error below
Program Terminating
Translation FAILED.
What might be the issue here?
Thank you
Best
Jamal
  • January 9, 2015
Hi Jamal,
Here is a no name parameter. I think it caused the error.
Try removing the no name parameter.
Usually you cannot define such a no name parameter with FME Workbench.
Someone edited the fmw file directly with a text editor?
Takashi
jamal
  • January 9, 2015
Thank you Takashi for the help,
I have just re-started the machine and then the workbench gets back to work properly as usual. The error doesn’t show up.
