Error connection on Featurewriter with Postgis
jseigneuret
I have a problem with FeatureWriter on v2020.1 32bit
I have no problem with direct connexion but i want use Summury result of FeatureWriter to continue insert or update on table and associated file.
this is the part log
Error connecting to PostgreSQL database(host='', port='', dbname='connexion validé', user='', password='***'): 'fe_sendauth: no password supplied
I use a connection so I don't undersand why host, port and user is empty
I have test my connection and all are ok
Best answer by jseigneuret
Ok ! Message to myself : DON'T USE ACCENTED CHAR IN A CONNEXION NAME!!!
jseigneuret
dbname is my connexion name and not the db name configured in this connexion
jseigneuret
  • August 28, 2020
arthur_bazin
Forum|alt.badge.img+14
  • October 27, 2020
Keep that in my mind... Same error, same mistake...
