Equivalent of Split Line at Vertex method of Arcgis in FME
  • Nov 9, 2017 8:57 PM UTC
  • 649 views
Hello
I need help with FME transformation. I am trying to split the route data collected with GPS into separate line segments at vertices. Then I need to find our the length of each line segment in miles or inches or yards. I need to figure out mph using distance and time.Time is fixed interval but need to figure out length for calculations.
Thanks for help!
erik_jan
Forum|alt.badge.img+26
  • Nov 9, 2017 9:06 PM UTC
The Chopper transformer can split line segments at vertices (option number of vertices = 2).
The LengthCalculator can calculate the length of the segments and store that value in an attribute.
  • Nov 17, 2017 7:15 PM UTC
All that worked like a charm!
Thank you so much!
