empty geometry field
  • Jul 11, 2013 10:37 AM UTC
  • 183 views
Hi all,
This is the issue:
I have an Oracle spatial (point) table where at least one record has an empty geometry field. The field isn't null, it's completely empty. This record caused my initial workbench to crash with an spatial index creation error.
I identified the offending table and started analyzing the table starting with a workbench containg only the table (using an Oracle spatial reader) and an inspector. That one gave this error:
An error occurred converting an Oracle OCINumber object to an integer: `OCI-22060: argument [2] is an invalid or uninitialized number'. (serverType=`ORACLE8i', serverName=`pkgnnat', userName=`KGNAT_HAVL', password=`***', dbname=`')
Error converting Oracle Spatial object geometry type to an integer: message was `An error occurred converting an Oracle OCINumber object to an integer: `OCI-22060: argument [2] is an invalid or uninitialized number'. (serverType=`ORACLE8i', serverName=`pkgnnat', userName=`KGNAT_HAVL', password=`***', dbname=`')'
This error kept coming back whatever I tried:
A geometryfilter (looking for null type object): error
Geometrextractor/ geometryremover: error
Command line Oracle spatial functions yield this error:
ORA-06502: PL/SQL: numeric or value error
ORA-06512: at "MDSYS.SDO_GEOM", line 70
ORA-06512: at "MDSYS.SDO_GEOM", line 1851
And a query looking for an empty field fail as well.
BTW: I identified the record by looking at the number of records the workbench WAS able to read and check the next one.
Any suggestions?
  • Jul 11, 2013 11:46 AM UTC
I'm not quite sure I understand what you mean by "The field isn't null, it's completely empty", but you could try to execute something like this on your feature table using e.g. SQL Developer, Toad, etc:
update MY_POINT_TABLE set SHAPE = sde.st_geometry_operators.St_geomfromwkb_f('POINT EMPTY', 0) where coalesce(SHAPE, '') = ''
This will insert an empty point geometry into all features where the SHAPE column contains either NULL or an empty string. You might need to modify the where-clause slightly if I've misunderstood the part about the empty field.
Remember to do a COMMIT after, if necessary.
It would be kind if you'd let us know if this works :-)
David
  • Jul 11, 2013 11:57 AM UTC
Sorry, there is an error below, the command should probably be more like this:
update MY_POINT_TABLE set GEOM = SDO_UTIL.FROM_WKTGEOMETRY('POINT EMPTY') where coalesce(GEOM, '') = ''
David
  • Jul 11, 2013 12:15 PM UTC
hi,
Thanks for the quick answer. This is what I meant when I wrote about the "empty" geometry:
An "valid" null geometry would have no ordinates but the value "NULL" for the SDO_GTYPE. That something I have seen before and is accepted by the client software (ESRI) I use. But here the entire record is empty.
SQL> select distinct(p.shape.sdo_gtype) from pkunstwerk p;
SHAPE.SDO_GTYPE
2001
You're solution would work but the workbench will have to convert about 200 tables every months so I am looking for an automatic solution.
  • Jul 11, 2013 12:42 PM UTC
one solution could be to forego the Oracle reader and replace it with a SQLCreator. The SQLCreator should include the SHAPE field cast as WKB (hint: sde.st_asbinary()) and a CASE-clause to return an empty geometry if the field is empty.
Hope this makes sense.
David
