ECW GDA2020 transition enquiry
  • Feb 21, 2023 5:48 AM UTC
  • 56 views
jaywen
Forum|alt.badge.img+4
We are currently using FME to run the process to convert GDA94 Zone 55 ( EPSG : 28355) ECW file into GDA2020 Zone 55 ( EPSG : 7855) , the output ECW was projected to the right location, but the CRS was not recognized by QGIS or other GIS platform. I have the FME bench as attached for your reference, could you please let me know if I missed any configuration settings or should use different transformer?
daveatsafe
Forum|alt.badge.img+24
  • Feb 21, 2023 6:52 PM UTC
Hi @jaywen​,
In the output ECW feature type, please try changing 'Use EPSG Code for Projection' from 'When Known Good' to 'Always'.
jaywen
  • Feb 22, 2023 3:12 AM UTC
Hi @jaywen​,
Hi @daveatsafe,
Thanks for your reply.
I updated the Use EPSG Code For Projection to 'Always', and the CRS for the output ECW is still flagged as invalid projection when added into QGIS.
Cheers,
Jay
