easiest way to add domains to FGDB in FME ?
  • Dec 4, 2023 7:40 PM UTC
  • 314 views
curtisd54
Forum|alt.badge.img+5
what is the easiest way to automate adding previously created domains to a new FGDB in FME ? or is it possible to manually recreate them in AttributeManager (similar to how you can create alias') ?
similar to how it is in ARCPRO show below
PXL_20231204_192804125
curtisd54
  • Dec 7, 2023 6:08 PM UTC
can anyone help me with this issue ?
panda
Forum|alt.badge.img+20
  • Dec 7, 2023 7:07 PM UTC
I believe you can create Coded Domain in Feature Writer. This functionality might not be available on older FME, But I use 2022.2 and I see it in there.
coded
curtisd54
  • Dec 12, 2023 4:44 AM UTC
coded
i dont require the coded domain though, just creating the Domain gives me an error
