Each column value in separate row
I am new to FME and I wish to make the following transformation.
IDColAColBColC1A1B1C12A2B2C23A3B3C34A4B4C45A5B5C5
To:
IDColumnNameValue1ColAA11ColBB11ColCC12ColAA22ColBB22ColCC23ColAA33ColBB33ColCC34ColAA44ColBB44ColCC45ColAA55ColBB55ColCC5
Can anyone help me out?
Best answer by ebygomm
AttributeExploder, keep Attributes set to Yes, followed by a tester to get rid of the format attributes and an attribute keeper to keep only the ID, attribute name and attribute value
Forum|alt.badge.img+39
  • March 24, 2020
  • March 25, 2020
Thanks a lot!
For a more generic approach for handling different CSV files, I've altered the Tester to:
  • March 25, 2020
fentanyl wrote:
Thanks a lot!
Yes, it's a pity that you cannot choose to ignore unexposed/format attributes when exploding
You can vote for it here
https://knowledge.safe.com/idea/19187/option-to-select-attributes-that-should-not-be-exp.html
drandall
Participant
  • Participant
  • April 10, 2025
Add a PythonCaller with the following def input() section:
def input(self, feature: fmeobjects.FMEFeature):
        attrs = feature.getAllAttributeNames()
        for i, attr in enumerate(attrs):
            attribute_feature = fmeobjects.FMEFeature()
            attribute_feature.setAttribute('field_order',i)
            attribute_feature.setAttribute('field_name',attr)
            attribute_feature.setAttribute('example_data',feature.getAttribute(attr))
            self.pyoutput(attribute_feature)
        pass
Attributes to expose: field_order field_name example_data
Attributes to hide: [SELECT ALL]
