Dynamic Statistics Calculator
  • Apr 26, 2023 5:40 PM UTC
  • 144 views
jdh
Forum|alt.badge.img+41
Is there anyway to configure the StatisticsCalculator on a dynamic set of attributes?
I would like to generate a histogram of attribute values, where the attribute name is determined at runtime. Bonus if I can process multiple attributes at once.
mark2atsafe
Forum|alt.badge.img+59
Could you set up a workspace to copy the selected attribute to a fixed name - like attr1 - and then hard code that into the StatisticsCalculator name field? But it looks like the StatsCalculator field name can be a user parameter, so would that work?
jdh
  • Apr 27, 2023 5:04 PM UTC
Hi Mark,
I had some success with wrapping the StatsCalc in a custom transformer with an attributeDereferencer.
However BAD Things happened when I tried to use it while looping through a list. Even with linked fmx, even with exposing the loop input...
