DWG: writing custom hatches (pat files) on a Linux/Kubernetes FME Flow
  • Jul 3, 2024 1:32 PM UTC
  • 0 replies
  • 135 views
jasperwis
Forum|alt.badge.img+19
I would like to write custom hatches in a DWG file. But our FME Flow is deployed with Kubernetes.
So the OS is Linux.
Since the RealDWG writer is only available on Windows, I will need to use the other DWG writer (Acad).
Where should I put these .pat files to write these custom hatches successfully?
The documentations says:
The ACAD format writer will look for custom hatch patterns in custom <filename>.pat files located in folder specified by the ACAD operating system environment variable, or in the related folder for any installed AutoCAD product.
On windows, I have tried to create an “ACAD” environmental variable, pointing to a folder where I placed my .pat files. But no result.
Secondly, will this be possible on a Kubernetes FME Flow?
Thank you in advance
Jasper
