Are you able to read the contents from paper space?
Hi, yes I can read the content from the model and paperspaces. Also I can print to pdf, but I can't print a specific layout, I can only print the modelspace
When you can read then you can write as well...
Any how could you kindly send sample file to check
Did you have the Paper space selected in the reader parameters? If you only want to read the A1L layout, you will want to deselect the Read Model Space parameter in the DWG Reader parameters (also have Read model space entities through viewport deselected).
I have attached a sample workspace that writes to PDF - hope that helps: DWG_Layout_to_PDF.fmwt
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
