DWG - open, transform, write - layout (paper space) issue
  • February 29, 2016
  • 6 replies
  • 140 views
I'm using FME 2016. My workflow is:
- open dwg
- transform (coordinates)
- write dwg
With FME 2016 I'm able to retain layouts but here is my problem: layout viewports don't seem to be transformed. After the coordinate transformation is done the viewports still point to where the data was before the transformation. I enabled "read paper space layout Information" and "read model space entities through viewport".
Does anyone know if transformer works an viewports as well and if so, how?
Thank you, Rob
  • September 8, 2017
Bumping this as we are having the same issue!
jneujens
  • September 8, 2017
For all I know, features having the attribute 'autocad_viewport_handle' can be tricky to write back to DWG. But I don't have any DWG files with viewports to test on. It would be helpful if you could share a sample dataset and/or your workspace?
jneujens
  • September 8, 2017
This article might also give you relevant information...
https://knowledge.safe.com/articles/34345/working-with-autocad-layouts.html
danilo_fme
Forum|alt.badge.img+56
  • September 10, 2017
Could you send us the log file and template workspace ( .FMWT ) ?
  • September 11, 2017
Thanks for your reply @jneujens!
os-local-transformation-test.fmw
hfp-pjv-1-dr-c-0208.dwg
Thanks for your reply @danilo_inovacao
Apologies, but where would I find those files?
